Ive noticed in System Control Panel that my 1.73ghz processor is currently running at 743mhz. In the manual it says this will happen but i dont think this changes when i load more performance needing applications.
Is there any way to make it constantly run at 1.73 or am i going to have to overclock it? If so can you guys recommend a good overclocking program.
Thanks
Are you running in adaptive mode? If you are then it will run at full speed if you encode a video or audio
