i have a problem with functionality of Fn keys.I can't increase or decrease the brithness of my netbook..
I'm with Windows 7 Starter...
I don't have recovery image with original software from Sony...
Anybody help ???
When you say that you no longer have the recovery image, do you mean that you have formatted the Recovery Partition on your HDD? If not, you can start the Recovery Utility by tapping F10 during the boot sequence. You can download the Recovery Guide for your model from here: -
ftp://ftp.vaio-link.com/pub/Manuals/RecoTS/2010Q2_TRG_EN.pdf
Alternatively, you can try reinstalling the Sony Utilities: -
Setting Utility Series
Vaio Event Service
from here:
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VPCW22M1E_L
And also the update for the Intel Graphics here: -
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VPCW22M1E_L
thanks for your help,but not worked for me.
I don't have recovery partition cause i have Ubuntu right after i buy it.
The new driver installation don't change anything.
Where i can get the recovery image from or what can i do ?
Hi vaio_vpcw22m1e,
What OS do you have on your VPV-W22M1E now, is Ubuntu or the sony supplied windows 7.?
Are you sure you've deleted the hidden HDD recovery partition.?
Try starting your vaio and when you see the Vaio logo hit the F10 key repeatedly, hopefully this will start the recovery process..:smileywink:
You can order a set of recovery disc's from vaio support, however you'll need to purchase a USB optical drive to use the discs. To find contact details for Sony Vaio support..
Open Vaio support, either by clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 2: Select your VAIO model, next to Select Model Category - Select your model from the drop down list.
Then next to Select Model
Then click Log-In
Once logged select Get In Touch
thanks for your help.After installing the drivers in order the Fn keys work perfect.
