Dear People,
got myself a very cute VPCW12S1E running on Linux Mint 18.1.
Slow as it is I would like to upgrade this little gem.
I already fpound out that 2GB ram is the max....
I wamt to go for a SSD (60 or 120) and maybe a faster CPU
What is the fastest CPU I can use and not overheat this notebook.
All just for fun and in order to use it travelling...
Thanks for an answer or sugestions.
Jan Volkers
Holland
Hi Jan
By all means try a SSD and 2GB RAM but the Atom single-core is almost certainly soldered into the main board and will not be economically upgradable.
Even if an upgrade to a dual core Atom 330 were possible the power requirement would increase from 2.5 watts to over 8 watts and if that power could be supplied, it would surely overheat.
Hi Jan,
It may help to check the support page for your computer here. There is a question and answer section plus manuals and additional information that may be useful. Hope this helps.
Best wishes,
Ed
Hi Jan
I was afraid of that..the soledred cpu.
I"ll stick to the SSD.
Thanks for your answers.
Jan
