Hi robynhairston and welcome.
It sounds like a keyboard and mouse driver issue. Have you made any changes on the Vaio recently!
Try, in safe mode, going to Device Manager (via Control Panel) find the keyboard (it will probably say PS2 Keyboard) and uninstall
the driver. Reboot and the system will reinstall the correct keyboard driver.
You may need to find a mouse driver and install it - I’ll see if I can find which one you need when I get home this evening.
Hey robynhairston, if the steps mentioned above didn't work, you might want to send it for inspection:
