Hi, I am trying to fix a Song Vaio VPCCA2S0E laptop. I canot get the webcam to work.
I have checked the sony europe support page and I cannot find a driver for the camera anywhere.
It coming up as a unknown device in the device manager. I tried uninstalling the device and reinstalling it and pointing it to C:\Windows\System32\drivers but still no luck.
If anyone can find a driver that will work or any other solution that will be great.
Many Thanks
SoulStrider
Hi SoulStrider,
To get the system to recognise the camera try the following:
In Device Manager, expand "Universal Serial Bus controllers” and delete all.
Then shut down and remove the battery/AC adaptor and press and hold the power switch for 30 seconds.
Re-attach the battery and AC adaptor and restart your computer. Windows will reinstall all USB controllers automatically and then hopefully the webcam will be recognised.
Rich
Hi SoulStrider,
Rich
