Hi guys,
I bought a vaio approx. 3 years ago and recently I am having this problem (see the pics) - there are vertical lines on half the screen and it's impossible to see anything properly. It works just fine with an external monitor. Do you think it is something with the screen and it needs replacing (was looking online for replacement screens and I could not find any) or is it a connection problem? Can anyone tell me what I can do next?
Thanks a lot!
Dan
Dan
Hi Dan,
as the problem does not appear on your external monitor then cause is more likely the screen or screen connections..
Unfortunately a new screen may cost more than replacing your Vaio but it may be worth contacting one of Sony's authorised repairers & see if they'll quote repair prices.
Tto find contact details for Sony Vaio support..
Open Vaio support, either by clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then click Log-In
Once logged select Get In Touch
Then Click on the Out of Warranty tab to locate the nearest location.
Hi Dan,
welcome to Questions & Answers..
Try connecting your Vaio to an external monitor, do you still have the same problem.?
Do you get the same problem when in safe mode.?
To enter safe mode restart your Vaio and when you see the Vaio logo press the F8 key repeatedly..
Do you get the same problem in the BIOS.?
To enter the BIOS restart your Vaio and when you see the Vaio logo press the F2 key repeatedly..
To exit the BIOS press F9 to reset the BIOS to default and press F10 to save and exit..
Thanks for the reply,
I don't have the problem when I use an external display.
But the problem persists in both safe mode and BIOS.
Dan
Hi Dan,
Then click Log-In
Hi Dan,
Whilst it's no consolation, yesterday evening, exactly the same problem occurred on my Sony Vaio VGN-SR19XN (purchased November 2008)
A few weeks before, the left side of the screen started to go dim, but now, I too am left with a striped left screen.
I have heard that it may be a loose inverter, and as the laptop is out of warranty, I think I'll take it apart and see whether it makes a difference. As you've observed, the display is pretty unusable.
I'll report back if it's made a difference (good or bad).
It seems to be a hardware problem (in this case you need to contact Sony technical support) however in any case you may try to remove and install the display driver again (after removing the display driver, MS Windows would automatically search for and install a new display driver again - it helped me once when I experienced display flickering on the HDMI output using the blu ray player).
My Sony Vaio laptop SVD1122C5E, the sceen has gone very bright in the bottom left corner and dark above on the left of the screen. Could it be a backlight problem? Can I get parts and repair?
Many thanks
John
