after i re-installed windows vista and ive downloaded all updates my Motion Eye camera doesn`t work at all
Please help me to find drivers for it, and i actually can`t fint any(!) drivers for this model
Thanks in advance
All downloads for your Vaio are here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-FE41E
You need to install:
1. Camera Driver (in Original Drivers Package)
2. VAIO Camera Utility (in Original Utilities Package)
3. VAIO Camera Capture Utility (In UPDATES Tab)
i found related problems here, ive tried them and it isn`t working
PLEASE HELP
all i need is a LINK where i can download all drivers for this model
i`ve tried Sony site and it`s nothing there, no drivers
THANK YOU VERY MUCH INDEED GUYS !
Thanks a lot Blencogo!
It works fine now, i`m still confused, i know for sure i`ve cheked the same site many times and couldn`t find them
Anyways, have a GOOD DAY & all the best to you !
My model is VGN-FZ250E and I have been trying since many days to get my camera working after installing Win 7 but it just wasn't happening. I have been to endles forums and tried out infinite drivers but none worked. Finally on one of the forums (http://www.sevenforums.com/drivers/61509-x64-drivers-vaio-vgn-fz-series-laptops.html) I found this download link http://www.hwupgrade.it/forum/showthread.php?t=1682490 which got my camera working. You may want to give it a shot - although it is originally in Italy, it isn't a problem since things are self-explanatory.
Hi Blencogo !
Please help me out again, i need the link with all the drivers for my VAIO VGN- FE41E, this one doesn`t seem to work anymore. I`ve tried to find them myself and i couldn`t, help me out PLEASE .
Thanks in advance !
looks like i found them, hope it`ll work fine
Have a good day & thanks anyways
Hi corneliusalvatore.
Good to hear from you again. Just for reference here is the updated link: -
http://www.sony.co.uk/support/en/product/VGN-FE41E/updates
It is possible that your battery has died. Try cleaning the contacts and try again.
Have you reinstalled all the Sony Utilities? In the original Preinstalled Utilities Package you will find a 'Battery Checker' Utility:
