Hi. I was looking over the internet to find out if there is any possibility to upgrade CPU to another one that will be compatible.
I have found out that I can upgrade up to 8GB RAM but nothing about the CPU.
Can someone tell me what is possible to upgrade in my laptop?
Thanks
Hi @Lenhard150,
in a previous model of your VAIO (European Models VGN-AW11) is it possible to replace the CPU, so, into VGN-AW41 too.
But the issue is, it's worth it? The processors are compatible with the Chipset are not many, dated, and not much more powerful.
Manolo
