Hello,
I have made format of disk in yesterday's day and temperature of processor totals from hold-down of software over 90 -st.C. Computer awfully is heated by that and it is awfully free. I have expanded for FRAMES also 2GB. Please, about help, because that not know already make but it needs computer for work. I will be thankful for assistance. Arcon
Hi Arcon,
welcome to Club VAIO..
have you tried cleaning the cooling vents of dust with compressed air (you should be able to get this from your local PC shop), check the instructions on the can before using because if used incorrectly you could damage the fan..
If you do not notice any improvement then your vaio may need to be disassembled in order to deep clean the fan and cooling vents..
