Was wondering about the possibilities of connecting my sony vaio to my tv so i can use the dvd drive and watch films on tv rather than the laptops screen,all i no is it has these connections below,are they suitable!! if they are where would
i be able to buy the cable to connect it to tv??
Steve
Sony Vaio
Model PCG-FR415B
Audio/Video Out ¿ VGA Monitor Out
All you need is one of those camcorder cables with the 3.5mm jack and the 3 phonos at the other end for the TV.
Kee-Lo
so i take it,that it is possible??
and would i use the 3.5mm jack end for the vaio and the other end to the TV,
Steve
You use the 3.5mm jack in the VAIO (usually on the back of the machine)
thanks
will get myself one of them leads..
just one more thing,i take it the Viao PCG-FR415B
can be hooked up to tv?
steve
should be and u can check by looking to see if u hav a jack socket which is coloured yellow. the 3.5 jack cable should have around 3 rings around the jack.
Yes, I wouldn't tell you to buy leads if it didn't now would I?
Kee-Lo
true,but i am just making sure..
steve
Steve
No problem, I understand.
