Hello!
I have the Sony Vaio SZ3HP notebook. I was wondering what the maximum resolution is for an external screen connected to the notebook via VGA or DVI?
Thanks,
frank
That depends on the driver and the cable length.
I'm using my PCG-FR315S with 21" widescreen at 1680x1050 pixels as extended desktop, if need more space and if I don't need my Desktop PC. But I have to use third party drivers to get it work.
Nvidia solutions are maybe more troublefree then Ati solutions. Well, all you can do is to give a try in your next shop.
nVidia say the nVidia GeForce Go 7400 is capable of display resolutions up to and including 2048x1536 at 85Hz.
But as Seb mentioned, this may not be available in the Sony OEM driver and you may need to use third party drivers. These may be supplied with the display.
