Hello ,
I have Sony Vaio SVE 1515Y1ESI. One Week Ago It stopped working and i tried to recover it from the Assist Button. Unfortunately it didnt work at all. I took the Laptop to Sony Store , explained the situation and they said they will try to recover it for me. After 2 Days then , they called me and told that they couldnt recover it and the would need the recovery disks ( i havent any ) , and even i am still under warrantee i ll have to pay for them.
Yesterday I went and took back the laptop home. I tried through Vaio Care and run Vaio Hardware Diagnostics
1. At the Quick Test , CPU is ok , Memory is ok and Hard Disk Linear , Random , Funnel and Surface Seek Tests are all failed. Does that means it has any hardware issues?
2. I also run the Hard Disk Verify and Repair , Where
partition 610Gb stucks at 1%
partition 28GB is ok at 100% and
partition 1,5 GB stucks at 58%.
(these are the partitions shown at hard disk verify and Repair)
Do you think is a hardware problem? My laptop is bought 12/2012 in Greece and still Under Warranty.
Do you think i have to buy the recover disks to solve my problem?
Thanks and sorry if my English are not so good
*The LAptop stopped working suddently , i hadnt any software change the last 3-4 months.
In the past , about 1 month after i bought it, it stuck again but vaio assist restored the windows 8 succesfully
Γειά σου Στέλιο,
Could you provide specifics and/or type(name, Model) of your HDD (new and old one)?
Perhaps is an AF(Advanced Format) issue.
Non mi aspetto nulla. Non temo nulla. Sono libero. - I hope for nothing. I fear nothing. I am free. (N.K.) |
Hello
My Hard Disk is 750Gb at 5400rpm.
Where i can see more of its Specs??
Does the results i get from Diagnostics mean a hardware failure?
Thank you!
