On start up my Vaio is saying S.M.A.R.T. drive detects errors, only 7 months old. Can i fix this? If so how? thanks..
Message was edited by: terrydoc1
Hi Terry,
What model Vaio do you have and does it have a single hard disc or two discs in a RAID 0 Array?
As you are still within warranty, I would report the issue to Vaio Link Support just in case a drive needs replacement.
I bought a Vaio in July. Very often when typing the letters on the keyboard they don't appear on the screen or they come later, or I need to click the cursor to start to type again. That makes my work extremely slow. I spent a lot of money for my laptop!
Can anyone help? thansk
