Can anyone recommend a competent, trustworthy place in the UK to send my 10-year-old Sony Vaio laptop to for repair?
There is a fault on the motherboard, and, so far, I have approached 4 places without success.
Thanks.
Doesn't get more trustworthy than authorized Sony service centres.
After going around the houses, I finally found out that there is only one approved Sony repair centre (for Vaios, anyway) in the UK. It is:
CTS
16A High View Drive
Chatham
Kent
ME5 9UN
PHONE 01634 681111
many thanks for your kind help putting onto the right track.
That was the first place I looked at, but when you visit the authorised Sony Service Centres, laptops are not on the list of equipment they service, no doubt because Sony abandoned laptop production a long while ago.
Did you use the "Personal Computers" filter when searching?
Glad to hear that ^^
Be sure to mark the thread as solved once you get some feedback so others can benefit as well
- JD
Hey @Martinrub,
It's a pleasure, and you've just added all of the needed information for anyone else in the future, so thank you too ^^
- JD
I’m happy your problem is solved but I guess there can be other users who need some tips.
