Hi does anyone know where I can get a genuine battery for my Sony Vaio laptop model SVE151J13M? I've not had any luck with ebay. Thanks
A search on Google for ‘Original Sony VGP-BPS26’ brings up a few hits at about £60.
You could also try searching using the correct Vaio name used for all support issues which is SVE1513B1E.
These are getting difficult to find!
