Can a sony vaio svl2412M1EB be wall ung
Hi jasper18 and welcome.
Yes, the SVL-Series Vaios can use a standard VESA mounting bracket (100mm X 100mm hole pattern).
Sony recommend their TV adjustable mounting bracket SU-WL100: -
http://www.sony.co.uk/product/tpa-tv-stands---wall-brackets/su-wl100#tab
Hi Emily and welcome to the forum.
As advised by Blencogo a standard VESA mounting bracket (100mm X 100mm hole pattern) will do the job.
Rich
