Hello, I ordered from the Ali motherboard A1563298A for my Sony Vaio VGN - AW11M / H, but I got the A1563297A, and the seller says it must work, so I installed it in my laptop and does not want to Boot anything, and NO access the BIOS, is like a stone, down I posted a video where it sees it stuck at the "VAIO" logo, so the seller says it's compatible and should go because engineers who know this, so I want to know if it is compatible, and how to make this motherboard work
Perhaps you should try Sony Support while you wait for a reply here. Sadly, I am not confident that you will get a helpful solution from either.
The Vaio logo screen you show does not look like the BIOS entry screen to me and I do question which BIOS version, if any, has been flashed. Sony has famously always tweaked and locked their BIOS versions.
Sprry I can't help further - Good Luck.
