hi,
i'm experiencing a problem with the temps of my vaio vgn-sz1: with system in full load (cpu usage 100% obtained running an istance of superpi at 32 M and prime95 torture test at the same time for 30minutes) i get a cpu temperature between 80 and 82 degrees. It's too high in my opinion: can anyone post his temperatures for a comparison?
i've read of a problem experienced by an italian user with his sony sz: after a month of usage the letters on the keyboard keys have began to be erased.does anybody else experience such a problem?
thanks
hi ....i've been having the keyboard problems with the letters erasing im afraid there is'nt a cure for this ...but you can contact sony and ask them for help if you still under a gurantee ...
love b
xxxx:smileycool:
Also remember enviormental tempretures are high, which will impare your test
it's unbelievable: i chose sony for quality and sony put a very low-quality keyboard on its sony sz notebooks....
i'm a bit disappointed
