OK I have bought a few Sony Computers over the years and never had a hardware problem and therfore no need to raise a suport ticket.
I would add that I own 7 other major items of Sony gear.
On the 13th.November just after receiving my new FE31Z , I found that the SD card reader adaptor does not work. Well, the computer will not function with it in place! and it will not read one of several different cards.
I have not even had an acknowledgement let alone a reply.
A pal had a different make of computer. There was a screw missing on the bottom. A day or so later a man arrived with the screw and insisted on fitting the missing part. You can probably guess the name of the other company
My question to you all reading this. Is this how Sony work? Or am I unlucky on this occasion?
Ian
If the notebook is as new as you say then I would telephone support. If they can't give you a fix for the problem then take it back to the retailer, tell them it doesn't work properly and get a replacement or refund.
I had to telephone them the first time when I got my faulty SZ series and I found them to be instant and helpful.
Its funny because I thought my transflash SD adaptor was faulty so i threw it in the bin... but maybe its the memory card adaptor thats faulty in the sony!
let us know how it goes
Thank you Rob. I sent the report to e-support and raised a ticket on the 13th of November.
If you need a quicker answer I'd call them.
