I recieved a vaio five days ago as replacement as myne was beyond repair since arrival the dvd door does not open i contacted sony today since i was busy at work was last 3 days i was given a case reference number the custumer support operator said i could get it repaired under warranty i declined as unit is five days old i want i new unit to my horror he said to me that i need to wait for weeks as they do not stock any laptops i was going off my head i told the support guy from sony that i need laptop for work and cant be without for one month i do not think he cares very much a also pointed this is a top of the range laptop worth 1500 pounds and this is not the service to give custumer which buys sony i will be contacting my local trading standard tomorrow and see if the can resolve this as is a joke in 29 years in glasgow this is the first time i come across a company like this i myself work in custumer service and this service stinks would never reccomend a sony to anybody thanks again godfathertre
Hi
Welcome to the forum.
Where did you buy the laptop? If you bought it from a store you should be able to exchange it for a new one as it's only 5-days old.
Hi
You could try writing to computer active they have a very good problems page and usually get a good outcome. If you tell the store you bought it from that you intend to contact the media they might sit up and pay attention.
As twisted says you have rights and they lay with the store you bought it from, don't be fobbed off with" it’s a Sony problem"
www.computeractive.co.uk
hope this helps
Atticmaster
Send it back, or as TR says take it to the store.
Hi
Might of been better to spill a drink on a Dell or an Acer than a Sony. Like Volvos great if they have no problems a nightmare if you do.
I think you're best calling the insurance broker
