I have a vpcec2SOE model. When trying to run Media Gallery, I get the message "Unable to run Media Gallery as Home Network Library is not installed". How can I obtain the Home Network Gallery to get it yo function.
Many thanks
Hi duncannon,
I believe the home network library is part of Vaio Media Plus. Try uninstalling Vaio Media Plus and then reinstall.
You will hopefully find the install program Vaio Media Plus under Vaio Recovery Center > Reinstall Programs or Drivers.
Rich
