Anybody have a list of supported media for this drive with the latest firmware? thanks
welcome to the club...
have probably the same problems as you with the drive...
As far as the firmware is concerned there is an update available through vaio-support, but I doubt whether it will help...
Check out the answers I recently got regarding the same questions following the thread "what discs should I use??? ".
Good luck
