I have had to re-install windows on my laptop but in the process I have deleted all the sony applications for volume/brightness controls etc. Does anybody know where I can get these applications back from ???
Please help!!
Dixon
You need to find a program called "Hotkey.exe" - should be on your recovery disk. Also can download at www.vaio-link.com
HTH
hiya. i have the same problem for the fr415b and i simply cannot find the bloody hotkey.exe thing anywhere. any chance of posting a link?
