All,
If you are having troubles transferring your files to your player (file not found or can't convert). Check in your library that the track names that fail do not contain semi colon's ;
If they do, edit the track titles to remove them and try the transfer again.
I think you will find the affending tracks will now transfer okay.
Automan.
