Hi. I managed to install the software fine but when I go to run sonicstage it comes up with this message: "Updating Sonicstage database. Please restart sonicstage after the updating has been completed." It just stays there and when I click on "OK" a box flashes up saying "Converting Stroage database" and then it dissapears in a split second. And that is it. I can't use sonicstage! I have XP Pro with Service Pack 2, if that is any help. So if anyone knows how to fix my problem please reply! Cheers
Does anyone know what to do? As I have tried everything from searching every page of this site to reinstalling the software. I can't even use the software! Please if anyone knows what to do then please reply.
Have you tried upgrading to SonicStage 2.2?
http://ciscdb.sel.sony.com/perl/select-walkman.pl for the download link.
Automan.
Cheers I will try it.
Only one little problem. I'm living at uni behind a firewall so I can't download the update!
I still can't get the installer to download the update! I have no idea of what to do!
I still can't get it to work!
