¿ have a problem with my sonicstage i cant fine how to put my pictures.¿f somebody could help mee:smileygrin: .That would bee great.
Thanks
If you mean assigning cover art to your albums, get the album pictures form Amazon or Discogs.com & save them to a dedicated file in my pictures.
Open SS and minimise the window a bit so you can open your cover art file and view both at the same time, then simply drag and drop the images to the album you want, I find 300 x 300 pixels to be the best size,
HTH
C
