Hi
I am getting the following error OMJBOX.exe error Application will be closed" while trying to transfer files to VP, and the SS is closing down.Same problem with the Vaio transfer tool.
I refered this issue in the software section i got a reply from one sony technitian that this error is due to the WINDOWS XP hot fix KB840987 and asked me to remove the fix and try.
I do not think this is a viable solution bcause removing a hotfix could impact the System security.
Can any one help me in this......I am not able to transfer any files to my VP
thank u
It sounds to me like your database is corrupt, if the hotfix is an issue look here for a bit more info, it may pay to UG to SS 3.1 too, some of the issues have been fixed in this new version.
C
Hi Chris,
Thank You for the reply. I applied some hotfixes recently and the problem has been sorted out. Thank you once again
Ramesh
