I have a Sony Vaio VGN-FE11S and it came with Roxio Digital Media SE and a bunch of other software. The problem is, that when I run Roxio it tries to uninstall its components from some source on the PC that is no longer available and when I click cancel like one hundret times it finally starts and everything is ok, but it's pretty annoying and if someone could help me, I'd be very grateful
The other issue that I have is that Adobe Photoshop Elements 4.0 says its user name and so on are invalid or unavailable and has to close and I don't know what to do on the matter
Thanks beforehand every answer would be appreciated
Hi nutter_bg,
Welcome to Club Vaio,
Have tried re-installing both Roxio and Photoshop Elements?
As the FE11S has a hard-drive recovery system, got Start > All Programs > Vaio Recovery Tool and click on Vaio Recovery utility.
Once the Vaio Recovery utility has loaded, click the options button and select Recovery Specific Applications that were pre-installed, click OK, then Yes and Yes again.
Then select Roxio or Photoshop Elements and click install..:smileyhappy:
Thanks
I have uninstalled both and used the recovery tool and now everything seems to work well
