Hi, I have had my vaio RS402 for 2 weeks and today it has started playing up by freezing and also now takes longer to stat-up, can anybody help any ideas????
hi
you might have to many start up items or to many processes it could be new hard ware if you installed some
you can start the machine up and then go to your bios and make it start up in default
spyware can also slow your machine down loads scan and remove any spyware ect ect
how full are your hard drives ????
i hope this helps
regards ben
Try the following to help us:
click "START"
click "Run"
type "msconfig -6"
click "OK"
and then please mention the list of applications that are listed in the displyed "Startup" register. Those are all the programs that are automatically launched at the boot-process.
Even most viruses will be listed here...
hi vaio tech dude
is it normal to have f:\setup.exe in start up
f; is my dvd drive
regards ben
note it has been reinstalled
shall i just remove it ????
