Hi - This is driving me mad - I have a VGC- RA204 which up until a few days ago worked fine. However on inital start up the thing seems to hang for a long time. Once at log on point you can log on o.k. I have re-installed windows which seemed to cure the problem. However as I loaded back the various software and re-booted the problem returned. I have now re-installed windows several times, same problem, except now it hangs straight from a fresh re-install Seems to have got worse). It does eventually start up and I can log on. Once logged on it appears to work O.K, except for this really annoying long delay in inital starting up. My suspicion is a hard drive fault - anyone any idea's ?
If you press alt+ctrl+del which process is using up the CPU? I am wondering if it's VAIO Entertainment Platform?
I have just switched on my PC to check the CPU usage. Now I had turned my mouse & keyboard off (to save batteries). When I switched my PC back on I forgot to switch the mouse & keyboard back on, but - hey presto it fired up as it should at the correct speed. I have tried this several times and still works.
A had connected a cable mouse & keyboard just before the problem arose - I am now wondering if this could be the problem. Anyway the processes being used are:
wuauclt.exe
taskmgr.exe
SNDrvc.exe
Launcher.exe
VzTrayIcon.exe
SSMSFillter.exe
acrotray.exe
pdservice.exe
AvRmCtr.exe
ALCWZRD.EXE
atiptaxx.exe
UsrPrmpt.exe
ccApp.exe
VAIOUpdt.exe
SOUNDMAN.EXE
SymWSC.exe
VzTaskscheduler
VzFw.exe
navapsvc.exe
explorer.exe
ccProxy.exe
spools.exe
ccEvMgr.exe
ccSetMgr.exe
sychost.exe
Isass.exe
services.exe
winlogon.exe
csrss.exe
smss.exe
VzRs.exe
alg.exe
VzHardwareReso
System
System Ideal Process
Wonder why that's happening?
wuauclt.exe
taskmgr.exe
SNDrvc.exe
Launcher.exe
VzTrayIcon.exe
SSMSFillter.exe
acrotray.exe
pdservice.exe
AvRmCtr.exe
ALCWZRD.EXE
atiptaxx.exe
UsrPrmpt.exe
ccApp.exe
VAIOUpdt.exe
SOUNDMAN.EXE
SymWSC.exe
VzTaskscheduler
VzFw.exe
navapsvc.exe
explorer.exe
ccProxy.exe
spools.exe
ccEvMgr.exe
ccSetMgr.exe
sychost.exe
Isass.exe
services.exe
winlogon.exe
csrss.exe
smss.exe
VzRs.exe
alg.exe
VzHardwareReso
System
Yeah prefetch is a pain in the butt
I see you have Norton installed.
Have you tried disabling it to see if it is causing the problem?
It does funny things sometimes on Startup and Shutdown.
Yeah it used to delay my bootup
