I am looking for a slim cover for my new VAIO VPCZ21C5E but I cannot find any.
I found this one instead for VAIO VPCZ21V9E...
http://www.sony.co.uk/product/p61-slip-covers/vgp-cvz3#pageType=Compatibles
Are those two VAIOs the same model but perhaps different colour?
Thank you.
Hi migonza21,
I would have thought that the VPCZ21 series would you the same chassis so I would guess the case should fit your model, however to be 100% sure it may be worth visiting your local Sony Centre & see if they have one in stock you can try..:smileywink:
Thanks for that Thalamus.
I am finding information on Sony's site quite confusing and going to a local store to see if they got a cover is kind of an adventure and time consuming for me, but as you suggest, that would be the best thing to do given the circumstances.
Thanks.
HI,
If I had to give a yes or no answer then I would say yes it's a 99% chance that the slip that you've found on the Sony site would fit your Z21..
I normally like to see & feel what the case/covers look like before making the purchase..
