Hi everyone, I need to pick your brains, I have an AR21S and would like to know the best way to hook it up to my Sky+ box (I don’t know if it makes any difference but the Sky+ box is a UK version) to record from it. I have tried just plugging in the Coaxial cable into the socket in the Vaio but the quality was not that good, anyone have any ideas?
Thanks
Thanks
Hi murdock1, im am trying to do the same thing as you with my ar21s, i tried using composite connections and tuned in the media centre to it, quality was much better than coaxial (tried it too and was rubbish as you said) and recorded some stuff from sky one etc. Lets hope there is more info from other CV members. :smileygrin:
Hi lurchbt what connection did you use on the AR?
Hi lurchbt, Thanks for input, what are composite connections and where do they plug in?
If your sky box has an s-video connection then you can use and s-video lead and connec the sky box the s-video in on the side of the laptop. if not then you can use a scart to s-video cable where the scart end is connected to the sky box and the s-video is connected to the laptop.
Hi Dekeshi,
Thanks for your suggestion I have been in touch with sky and they say that the s-video on the back of the sky+ box is not connected to anything and the s-video dose not carry sound.
Thanks,
Murdock
Hi again, Vas, i connected a composite cable(has a type of jack plug that resembles a headfone connection and has 3 A/V connectors at other end, yellow for video and a red and white one for audio left and right) to the right side of the Ar21s(beside firewire connection) The 3 A/V cables connect to the back of the sky+ box and the other to the vaio.Media Centre has then to be set up in add new channells section.
Thanks I will give it a go.
Murdock
Murdock1, any luck with your ar21s and sky+ box.
