Hello,
i'm the owner of a VGN-FS215M notebook, and i would like to delete the D partition and have all software and data in the C. How could i do that? I tryed the recovery but it don't give me the possibility to total delete the D partition.
Thanx in advance and sorry for my english
Denis
I cannot say that is not possible, I cannot also advise that it should be done.
The question would be: What do you win in just having one drive?. I think that anything, because normally the drive C stores programs and the drive D Data.
I don't believe that there will be a performance earnings.
The one that I imagine is you to use an old resource of DOS and to format the disk C.
Then you would have the wanted result. But I cannot assure that with the recovery disk you could install Windows without doing the partition. I think it is possible. But it is not advisable.
I still asking again, because you won't win anything in performance and it will be necessary a great care when it stores information (data) in her personal computer.
It is only a point of view than a technical subject.
