got a Vaio VGN-FS515B Win XP SP2. And the shutdown process takes too long, sometimes nearly up to two minutes. Is there any workaround for this prob?
Is this a known prob
Thanx
raimundus
It is Norton thats the Problem, But to solve the problem you got a bigger one definately if you want to uninstall it.
You can't get rid of it, it was made to stay but however on the symantec website somewere on it is a UnInstall key.
Other security apps do work while its still there but it hinders them.
Right, bear in mind I also have and use Norton, my shutdown last night took 45.25 seconds approximately. I find that very acceptable.
But you are not the one who has the problem
However, the original poster has already said that they aren't running NIS . . . .
