Does anyone know which drivers the FN keys and the S Buttons come under please.
Thank you in advance
Tash
To get your FN & S Buttons to work you need to Download the Sony Pre-installed Utilities from VAIO Support
Create a Folder to store in & then in order for the function keys to work, you will need to install these installers from the Utilities in the correct order:
1 Sony Utilities (folder 1) 2 Sony Shared Library (folder 2) & finally 3 Vaio Event Service
