hi just bought VPCEB4D4E but can't get past set up windows n the touch pad isn't responding any help plzzz...
Hi durrana32,
if you touchpad is not allowing you to start the recovery wizard & as your vaio is new I would suggest you return it to the retailer an ask for an exchange..:smileysad:
Hi durrana32,
welcome to Questions & Answers..:smileyhappy:
As you have just bought your Vaio I suggest doing a system recovery..
To recover from the recovery area
On models with the ASSIST button
1 Press the ASSIST button while your computer is off to launch VAIO Care Rescue.
If the display language selection window appears, select your desired language and click OK.
2 Click Start recovery wizard.
To perform the custom recovery, select Tools and click Start advanced recovery wizard.
3 Follow the on-screen instructions.
On models without the ASSIST button
1 Turn on your computer and press the F10 key several times before the VAIO logo screen disappears.
If the Edit Boot Options window is displayed, press the Enter key.
2 Select Start recovery wizard.
thanks for the reply THALAMUS
did wat u said but since my touch pad is also not responding i m unable to click (start recovery wizard ) any help regarding touch pad thanxxx....
