i m looking for sony vaio model pcg-71911m sccreen . so where can i buy this product ?
Hi pinalpatel and welcome.
Google will find several screens for you.
However, I would use the correct model name to make sure you get the same resolution. The correct model name will start VPCExxxxxxx and you will find it on the screen surround or in Vaio Control Centre -> System Information.
http://www.laptopscreenonline.com/sony-vaio-pcg-71911m-laptop-replacement-screen-19555-p.asp
