I have bought a new laptop just one week ago, Sony VGN-FJ1S. But I found a problem with it. When I was using it, it suddenly display white screen. I know all the programmes were processing well, because I can hear the music quite well. But the screen shows nothing, but totally white color. You can not work on it anymore. This problem happened three times. So what can I do now?
You could bring it back to the shop it was bought in and change it
It will be the best solution for sure.
