Sony VAIO Laptop Model VGN-CR42Z/R turns on but the screen remains dark all the time. I still can see a very dim image. The laptop works fine with an external monitor.
Hi wellasony,
welcome to Club VAIO..
I take it you have checked the Vaio's brightness settings..
It sounds like the inverter but it also could possibly be a faulty cable or backlight bulb..
I suggest you contact Vaio support to arrange a repair, either by clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 2: Select your VAIO model, next to Select Model Category - Select your model from the drop down list, in your case VGN CR
Then next to Select Model - select CR42Z/R
Then click Log-In, the click on the Get in Touch tab
Or
Alternatively get a quote from a local repairer in your area..
