I have a Vaio Tap 20 which, after 2 weeks, has suddenly developed a thin bright green line vertically down the screen. I have rebooted etc but the line won't go away. Does anyone have any suggestions for what might cure the problem?
Thanks,
Hi Peter,
welcome to the Sony User Community..:smileyhappy:
As your Tap 20 is only two weeks old I would be inclined to suggest you contact Sony support as your Vaio may require repair/replacement..
To locate contact details for support please click the following link - Sony Support
Hi Peter,
One month old and exactly the same problem about to return computer to Sony for repair I hope this isn't going to be a recurring problem.
