tried to calibrate monitor with hex2bit now my colours are washed out how can i get back to default settings
hope someone can help thanks micky
What model Vaio are you talking about and which Graphics provider does it use?
In general terms, you need to right-click on a blank area of the desktop -> Properties -> Settings -> Advanced
and look for the Colour Management Tab under your Graphics Adapter. You will see a list of Colour Profiles associated with your display and you will need to remove the new profile or reset the profile to factory basics.
thanks went into ati and reset to factory settings
