Am having a problem were my screen has recently started flickering. The laptop (PCG-GRT915M) doesn't feel particularly hot. Is over heating the problem or has anyone got any idea as to other problems that this might be. A little disconcerting when you try and work in front of a dodgey screen.
Heard of this problem before, make sure that your screens refresh rate is at 60 Hertz..although im sure it is..
Ring the Vaio support line as it sounds like it could be a screen fault
Cheers man!
