Hi all again ok got my modem instaled for broadband works great problem is i now have the icon to safely remove hardware desktop icon up all the time and cant get rid of it it just lets me remove it ?????
any help
Yeah but I bet ya a million posts it don't happen until they change to php. I really think they would be better off just changing platforms and starting again setting up a quick phpBB board or something.
They used to have PHPBB too
do the folks at sony support ever read the forum they might learn a thing or two about the real problems we have and stop giving us stock answers to our enquiries which very rarely help.
or failing that put vaio masters on a commision so when they are stuck on a problem they would get in touch with kee-lo and the rest the masters, £10 an answer would save a lot of money and time. good idea or what ?:smileylaugh:
Sony support sounds awfully unpopular lately. What are they doing wrong?
Brian, imagine if I got a tenner for everyone I helped........... WOW
As for the firewire any 4pin - 4pin cable should be ample.
you wouldint be on here now if you got a tenner each time lol
yup i bought the cable but needed info on why i had a 4 pin cable point on the front and a 6 point one on the back and what i could all use the fire wire to do that i couldint with the usb cable that came with my camcorder
i bought the 4 to 4 pin cable already but not from sony :smileygrin:
i would have had they been helpfull
Sony is a bit of a ripoff. Unless you're buying a Vaio look elsewhere for peripherals and cables and things.
And their support does sounds fairly hopeless from what you say. Like the type where you ask a question and they send you back a template email about something completely unrelated to what you asked.
Brian, FYI 6pin FireWire carries power - 4pin doesn't.
