I HAVE TRIED MANY TIMES CONTACTING SONY ABOUT THIS PROGRAM THAT IS IN MY LAPTOP AND I HAVE BEING TRYING TO UNINSTALL,SONY COULD NOT HELP.THEY MAKE SURE THEY PUT THIRD PARTY SOFTWARE & PROGRAM ON YOUR LAPTOP BUT YET THEY DO NOT WANT TO HELP.I HAVE SENT 6 EMAILS TO THE MANUFACTER BUT YET NO REPLY.YOU CANNOT UNINSTALL IN ADD & REMOVE OR DELETE IN PROGRAM FILES EVEN ON THEIR SITE THERE IS NO REMOVAL TOOL AND THIS IS ONLY A TRIAL VERSION.HAS ANYONE GOT AN IDEA HOW TO UNINSTALL IT THANKS
Hmm That's strange I removed SafeGuard PrivateDisk from Add & Remove Programs
Some trial programs need to be activated before they can be removed using Add/Remove programs…..
GO TO START > RUN> REGEDIT> H KEY CURRENT USER > SOFTWARE > mICROSOFT > WINDOWS > UNINSTALL AND DELETE THE PROGRAM IN THE LIST. jUST DOUBLE CHECK BY MAKING A SYSTEM RESTORE POINT INCASE IT ALL GOES TITS UP.
No the folder has gone now.
I agree Rich, but I did not activate the program I just removed it.
Did you actually use the program amj.designs?
Regedit not msconfig:smileygrin:
There nice airbags Beardo :smileygrin:
