Is it normal S3XP runs very hot, especially the right-hand side, both bottom and under palm-rest? What range is normal? How to tell if the temperature is ok or something wrong?
What kind of material was used for the case?
p.s. I can't find the following software in the App Recovery disc, so suppose I need to re-install one, do I need to do it by doing Sys recovery?
List of software I didn't find:
WinDVD5,
VAIO Launcher,
VAIO Recovery tool
They're known to get hot, and Sony say it's normal
Those programs should be on your recovery DVD
They're known to get hot, and Sony say it's normal![]()
Hahaha
I think it's selling as a hotplate laptop.
