Ive been using it for a few weeks now & Im extremely disappointed, apart from the speed its no better than my old RX203 & as for the server capabilitys its quite useless. I really dont think it was worth close on £2000. Charliepat
comparing spec you could have bought a much cheaper one, i bet you bought the sony only for its design like many others
I bought it mostly on Specs, Network capabilities & Reliability, & yes I have made an expensive mistake.
