I have just installed a 1GB DIMM moduel into me rz422p vaio and the monitor will not boot up.
will the pc see a 1GB moduel?
all help welcome
yes
it states that it will do
thanks
jim
Plug in the external monitor so you can see what the problem is and reinstall the utilities from Vaio Link. Delete the monitor driver and reboot it will reinstall it
I could be totally off track here BUT....
Does it boot OK if you remove the memory again?
If so maybe you have to install them in pairs?
I was was under that belief when I upgraded the RAM on my RZ502P.
I am pretty certain that William has hit the nail on the head there. The RZ422P has 4 slots (2 banks of 2) which means that modules must be ordered and installed in pairs.
Thanks Guys
I had asked on another site if I need to install in pairs and I advised that I could install a single moduel.
The Crucial checker indicated that a single unit could be installed.
The answer to Williams question is no the pc did not boot up.
I have returned the memory to the supplier with the hope of an exchange to 2 units
Again thank you for all of your help it is very much appreciated
Jim
Jim
So it is RDRAM?
