hello, could somebody please tell me the brand and model of the motherboard used inside RX402? Could you also please tell me the fastest ATHLON cpu supportet by the board? will the cpu fan work with higher clocked cpus?
thanks a lot!
chris
nobody?
first of all, you'll have a Motherboard from ASUStec in your Desktop. That Board is not listet
at the Homepage from ASUS.COM. I think it is a Special Build for SONY.
The Type is: A7N266-VX, but you will never find anything about. It is a MICRO-ATX-Board like the A7N266-VM from ASUS. These Information is readout from SANDRA, a Sharewareprogramm for Systemmanaging.
The fastes CPU which is supported is (I have it read somewhere) the AMD XP 2400+!
I hope this is usefull for You
Merry Christmas
Greetings Jo. Liebich
You really need to get hold of a service manual. Check out VAIO-Village, and see if someone has it there.
