Hello everyone
I need to install a 'dual head' graphics card in my RX-201 to run two monitors simultaneously.
Does Sony recommend a suitable card?
I am considering either a Matrox G550 or a Matrox Parhelia 128 Mb - does anyone know if these will run OK on this PC? Is it as simple as taking out the existing card and installing the new one?
I am a graphic/web designer, so any suggestions welcomed for a card which would be suitable for my usage.
Thanks
Any of the Geforce FX 550's should do nicely, make sure they support dual head.
Any of thew new Nvidia cards or ATI cards will be fine (as long as its AGP)
Thank you both very much.
Kee-Lo - would the Matrox Parhelia 128 Mb be OK? I think its a newer model with DVI support?
Jaan - will check out your recommends.
Thanks again
Never heard of it.
Mark - the Matrox is a great card - it'll even do tri-monitor support (though I have never used it).
However, the main big boys right now are NVIDIA & ATI and they do have some great cards out.
Jaan
Would the Matrox card be OK for my Vaio?
The spec on the Matrox site on says that it needs to be:
AGP 2.0 compliant system
128 MB RAM
600 MHz CPU
Microsoft® Windows® 2000, Windows XP, or Windows NT 4.0 operating system
(check regularly for updates on support for other operating systems)
300W system power supply
CD-ROM
I wasn't sure about the 'AGP 2.0' aspect on my Vaio.
Kee-Lo
Here's the link to the card, just in case it's of interest:
http://www.matrox.com/mga/products/parhelia/home.cfm
Thanks once again for your help and advice
I can't get onto the Sony site for some reason to check the specs, but if your PC is less then 2 years old then you will have an AGP2.0 slot.
AGP 2.0 is normally a 4x-8x bus?
The worse that can happen is that you buy a 4x card and your AGP slot only supports 2x, therefore it will run at 2x.
Let me see if I can get onto the tech specs for your PC to confirm.
