Hi Folks
I own a notebook model PCG-FX902P but I am running out of harddrive space and I wonder if anybody out there can help me or advise me to upgrade to a bigger drive and where I can get help in this matter.
Living in hope
regards
alfredbeaven
http://www.kahlon.com/rm202796_Sony_VAIO_PCG-FX902P_FX905P.html
nice seller of spare parts..dunno its a US site so probably only helpful if u live there..
otherwise, google it.. and u should get a load of results
Shouldn't be too difficult - what size is your current drive?
Also consider using an external firewire/ilink drive.
I'd recommend the external USB2/Firewire drive option too.
Couple of points to note:
Just beware of USB - assuming your laptop is USB2.0 (480Mbps transfer rate) then it'll be OK for a disk drive. If you hook up any other USB devices while the disk is connected then they might drag the USB speed down to USB 1.1 spec 12Mbps or worse.
USB will provide power to the disk.
Firewire/iLink is good but the 4 pin found connector on most laptops doesn't supply power to external devices so the power brick is needed.
You can buy external packs that'll do both - e.g. 80GB USB2/Firewire drive
However, I just put the same spec configuration together for a friend by buying the enclosure 2.5" disk Enclosure and Hitachi TravelStar 5K80 disk from dabs.com separately for about £150 total.
That new WD 250GB drive is very nice with it's card reader, USB2 and Firewire.
